sketchup file for CFD with fluent
Old   May 19, 2011, 14:24
Default sketchup file for CFD with fluent
xvisiecle is on a distinguished road
Hi
Does anyone knows or ever tried to convert a sketchup file in other extension and successfuly opened in fluent??
I want to simulate a formuler one model with fluent to compare it with the data obtained from wind tunnel test. I could not find a 3d cad file of F1 on the web and neither I don't think I can draw it without any 2d drawing of parts(it will take much time also).
so I searched for a solution.
someone adviced me to add a file for use of plug-in of GAMBIT named, skp_to_dxf.rb for conversion from sketchup to .stl file.
so i found a sketchup file of the formula one model and
after consulting several messages I succeded to convert the F1 sketchup file into .stl,.igs,.catpart
I can open the file in .stl format in GAMBIT. But I don't reach to open those files in FLUENT. it indicates an error,
"no cells in zone, id = 0, ind1 = 1,indn = 0Reading Cells: failed while reading section 12"
it's the same case for .igs format.
Thanks so much for your comments!
xvisiecle is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
.msh file cann't be by Fluent nchuche FLUENT 1 June 29, 2010 11:38
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
