How to launch fluent 6.3.26 on Ubuntu 11.04
Old   May 14, 2011, 11:03
Default How to launch fluent 6.3.26 on Ubuntu 11.04
Daniele
Fiska is on a distinguished road
Hi guys!
I've just installed fluent 6.3.26 on Ubuntu 11.04, but I cannot launch it.
The software should have been properly installed, but I cannot find the right command
to launch it.
Could you help me, please?
Thank you in advance.
Fiska is offline   Reply With Quote
Old   May 16, 2011, 16:14
supertramp is on a distinguished road
If Fluent is properly installed on your machine, you should open a terminal and enter,
fluent 2d
command to run Fluent. If terminal does not respond you positively, Fluent commands are not known by your bashrc file. In Ubuntu you can find your bashrc file in /home/user folder. Notice that bash.bashrc file is hidden. You should add these lines at the end of your bashrc file:
PATH=$PATH:/where_fluent_exist/bin
I hope this helps you.
supertramp is offline   Reply With Quote
Old   May 16, 2011, 17:36
Amir's Avatar
Amir
Amir is on a distinguished road
In ubuntu 64 bit you will also need some other packages to execute FLUENT 6.3.26.
Amir is offline   Reply With Quote
Old   May 21, 2011, 14:01
Daniele
Thank you..
Which ones? I tried to follow the instructions by supertranp but I couldn't result positively..
Old   May 21, 2011, 16:33
Amir's Avatar
Amir
I used these 4 packages and it worked for ubuntu 10.04 LTS (lucid) 64 bit:
http://mirrors.kernel.org/ubuntu/poo...ntu4_amd64.deb
http://forum.ubuntu.org.cn/download/...18176738d4db38
Fluent version 6.3.26 wlt_1985 FLUENT 0 April 18, 2011 00:03
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Install Fluent on Ubuntu 9.05 Ronnfors FLUENT 3 September 24, 2009 03:21
Difference between Ansys12 and fluent 6.3.26 vishwa FLUENT 1 September 3, 2009 16:02
Fluent 6.3.26 -> starCD 3.26.027 by using CGNS steph Siemens 1 April 3, 2008 17:14
