Problem using dynamic mesh: unexpected velocity distribution |
May 13, 2011, 13:11 |
Rep Power: 15 |
Hi everybody!
I am running a transient simulation using Dynamic mesh to define the motion of my system (angular acceleration of a solid full with fluid). The motion is correctly defined but the result is unexpected. The velocity is correct at the boundary but unable to diffuse into the whole fluid zone, as it should do. It looks like Fluent isn't able to manage properly the transition between time steps. Does anyone knows how Fluent manage parameters between 2 mesh positions? Do you know where my problem may come from? Thank you very much for your help! Tobard |
dynamic mesh, time step, velocity distribution |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
A problem in dynamic mesh | svh | FLUENT | 2 | October 12, 2004 13:50 |
Dynamic mesh problem | Karthick | FLUENT | 1 | October 11, 2004 06:47 |
Divergence in Dynamic Mesh Problem | James | FLUENT | 0 | September 28, 2004 09:43 |
