April 20, 2011, 04:52 |
Convergence issue in Fluent
Javier
Rep Power: 15 |
Hello.
I am having some problems finding convergence with my case of study. I am studying the flows in between the blades of a high speed centrifugal pump impeller. I cannot make the residuals go any lower after 500 hundred iterations approx. It seems like they are stuck. The order of my residuals are:
I monitor the mass flow rate at the outlet and it gets stable after 500 iterations so it seems like I reached convergence but my lab mates told me I need at least to reach 10-3 I’ve looked at the results and everything seems to be okay. Tip speed, Inlet/outlet velocity, static and total pressure, mass flow rate, velocity vectors… Can I trust these results? Or how can I improve the residuals? I've done many different tries... It weirds me out that which such less iterations I could get some good results in something that theoretically seems complicated… I’ve done some other simpler studies with Fluent and it required me many more iterations. Any suggestions? Thanks |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Fluent 12.1 on Linux x64 Architecture Issue | fivos | FLUENT | 5 | April 24, 2010 15:19 |
Convergence issue with fine grid | itisharisankar | FLUENT | 0 | June 27, 2009 02:02 |
convergence issue | Rohit Kumar Batra | CFX | 1 | March 27, 2008 17:43 |
Fluent 5.0 boundary condition issue with RSM | Flav | Main CFD Forum | 2 | October 20, 1999 04:57 |
