How to read or write case by commands during simulation with Fluent
Old   April 19, 2011, 10:17
Default How to read or write case by commands during simulation with Fluent
lzgwhy is on a distinguished road
Hi.
As we all know, one can use text command to set in Fluent and Fluent can write case and data files automatically during simulation, but can read case and data files automatically. I want to read or write automatically case and data or some other files during simulation, if needed, but I do not want to use GUI, because it is not what I need. In other word, when the simulation is started, I want Fluent to read or write case and data files by itself not by hand, if needed during simulation. How can I fix this problem by text command? Thanks!
lzgwhy is offline   Reply With Quote
Old   April 19, 2011, 16:42
Amir's Avatar
Amir
Amir is on a distinguished road
you can do that with a simple journal file.
Amir is offline   Reply With Quote
Old   April 19, 2011, 22:14
How can I do so? Could you give me some simple example? I always use journal file to make setting, but never do a automatic reading setting.
Old   April 20, 2011, 14:41
Amir's Avatar
Amir
rcd 123.cas
it 1500
wcd 123.cas
the journal file should be place in the same folder as your .cas file. you may need some 'yes' or 'No' command between for overwriting ....
Old   April 20, 2011, 23:02
Thanks for your help. However, I should describe my problem more clearly. For example, I plan to iterate 1000 steps for an unsteady simulation. During the simulation, I want to automatically let Fluent read case and data files, if needed. For example, when the 101 step is finished, by a condition, Fluent should read the 100th step files, i.e. 100.cas and 100.dat automatically without manual operation and calculate the new flow field of the 101st step. The case of writing files is similar to that of reading files. How can I fix this? Thank you.
Questions on an impeller simulation with Fluent Angelo D'Ettore FLUENT 4 July 7, 2010 11:08
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 06:05
text shortcut commands for fluent senthil FLUENT 0 November 21, 2007 14:39
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
How to make my CGNS solutions to be read by fluent Guo-dong Lei FLUENT 0 November 26, 2005 21:59
