April 18, 2011, 16:45 |
Defining DPM Particle Injections with a UDF
patty
Rep Power: 15 |
Hello all,
I'd like to inject single particles with varying properties at specific locations and at specific times that are not known at the start of the simulation. I know I could easily define injections before the simulation if I knew all the details then. I'm already using a UDF to identify the time and location a particle is to be injected. Does anyone know of a way to create injections that have not been defined in the injections GUI using a UDF? DEFINE_DPM_INJECTION_INIT only works for injections defined before the simulation begins. A text injection file seems like a possibility, but wouldn't the injection file need to modified on the fly? Is that possible? Any suggestions are greatly appreciated as I can't find any documentation on this in the forum or in the user's manual. Thank you in advance, Ted |
dpm, file injection, injections, udf |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | Fluent UDF and Scheme Programming | 0 | August 19, 2010 03:09 |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | FLUENT | 0 | August 19, 2010 03:01 |
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT | subhankar_bhandari | Main CFD Forum | 0 | August 19, 2010 03:01 |
Velocity of Fluid @ different positions of Particle in DPM using UDF | pmghadge | FLUENT | 1 | June 16, 2009 19:11 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
