Aluminium<solid> to Aluminium <liquid> conversion in material panel
Old   April 17, 2011, 13:14
Default Aluminium<solid> to Aluminium <liquid> conversion in material panel
zino
zino is on a distinguished road
Hi!
I m facing a problem in defining aluminium liquid at high temperature through Material panel in FLUENT.
can anyone have idea? what if i define new properties by overwriting water<liquid> but viscosity in that case is unknown.so, in that case should i take water's viscosity?
zino is offline   Reply With Quote
Old   April 22, 2011, 10:25
Default Re:
svp
svp is on a distinguished road
I am assuming the viscosity of water is going to be much less than what you would want to simulate for viscosity of molten aluminum. You should probably look up material property tables for molten aluminum that give you a value of viscosity in the temperature range you are interested in (might be difficult to find). Even if you were to find a an equation for viscosity as a function of temperature, you could and probably should implement it using a UDF.
svp is offline   Reply With Quote
Old   April 25, 2011, 12:02
Default searched
zino
Thanks for replying svp
yes. it is
Old   April 25, 2011, 12:04
zino
Yes I searched a lot and it seems i have to put some supposed value.
should I take value for liquid water as alumina liquid?
aluminium, material, material properties
why can't I delete aluminum in Material panel sean FLUENT 11 April 7, 2024 12:26
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
physical properties in material panel. NEIL FLUENT 0 April 26, 2007 15:30
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
