DPM transient laminar flow over a cylinder
Old   April 12, 2011, 00:40
Question DPM transient laminar flow over a cylinder
JSoares is on a distinguished road
Hello everyone
I´m trying a simple case:
A flow over a cylinder at Re=80, with unsteady formulation.
I turned radiation scheme "do", so that the cylinder send radiation.
Then i inject particles to measure uv radiation that every particle had received.
I´ve doubts and problems:
1- Should i turn on dpm after the flow and radiation convergence or should turn before any simulation.
2- I inject particles from a surface "inlet" and i didn´t change start and stop time. should ?. The problem is that if i check unsteady particle track it happens nothing (literally), but if i uncheck that optinon i can mesure radiation i every particle. i don´t understand waht i´m doing wrong.
Notice that I have and udf implmented that mesure this quantities and works real fine.
In advance thanks.
JSoares is offline   Reply With Quote
Old   April 12, 2011, 03:37
tirtha
tirtha is on a distinguished road
hi
once you will use dpm , i guess you have to give ESCAPE condition on the "inlet" and "outlet"
try to give a certain start and stop time and see whether your getting any particles inside your geometry.
im not sure but it may help,
tirtha
tirtha is offline   Reply With Quote
dpm, laminar, radiation, transient, unsteady
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 06:49
Validation for laminar Disperse phase flow shashwat Main CFD Forum 0 April 4, 2008 03:20
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 12:01
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 10:18
