keeping resolution of mesh in Dynamic mesh + Q about posprocessing the problem
Old   April 10, 2011, 08:10
Default keeping resolution of mesh in Dynamic mesh + Q about posprocessing the problem
M.Sc_Student is on a distinguished road
Hi
I am simulating an unsteady periodic motion of an airfoil with pitch and plunge motion, and I have these questions regarding this problem:
1) how can I keep the resolution of mesh, by using dynamic mesh parameters? for instance how can I specify a maximum cell size in order to have all the new cells in the updated mesh below this size?
2) I want to compute the mean lift and drag coefficients, is it possible to do this with fluent? or for instance I want to normalize some forces by dividing them to an specific amount or compute the Cl/Cd ratio. how can I do this in fluent?
3) how can I write the data presented in fluent in an data file? lets say .txt
Thanks in advance
M.Sc_Student is offline   Reply With Quote
Old   April 10, 2011, 10:54
Amir's Avatar
Amir
Amir is on a distinguished road
in surface->monitor->surface (or forces) you can write you desired data every time step and in another post processor find the mean value
first export your data to tecplot and then open the saved file in a text editor.
Amir is offline   Reply With Quote
Old   April 10, 2011, 11:09
Dear Amir
Thanks for your comment, I would really appreciate it if you could tell me How can I import data to Tecplot?
Thanks
Regards
Old   April 10, 2011, 13:10
Amir's Avatar
Amir
Originally Posted by M.Sc_Student View Post
Dear Amir
Thanks
Regards
there are 2 ways for that:
1)
first export file from fluent to tecplot:
file->export->tecplot
then in tecplot:
file->load data files->tecplot data loader
2)
in tecplot:
file->load data files->fluent data loader : read your case and data
if you want to access your data e.g. in a txt file you can follow first procedure and then open the exported file in a text viewer or you can follow both procedures and after importing files in tecplot:
file->write data file ...
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
problem on dynamic mesh zone erkan FLUENT 2 January 8, 2009 17:01
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 22:17
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 07:44
A problem in dynamic mesh svh FLUENT 2 October 12, 2004 13:50
