numerical diffusion & patch operation
Old   April 10, 2011, 03:02
Default numerical diffusion & patch operation
ronen
ronen is on a distinguished road
1. What are the options available to avoid numerical diffusion?
2. When I patch a small volume I get an avaraged value of the specified parameter at the marginal grid of the volume. How can I avoid it?
Thx
ronen is offline   Reply With Quote
Old   April 10, 2011, 10:57
Amir's Avatar
Amir
Amir is on a distinguished road
it doesn't occur if you display cell values not node values. (you can set that in display->contour)
Amir is offline   Reply With Quote
Old   April 10, 2011, 13:17
ronen
Thx for the quick replay, the tip helped and works
What about the Numerical diffusion? The mesh is refined and the results are still exhibit significant false diffusion which is beyond the resonable for the mesh size. What can I do about that?
Old   April 10, 2011, 13:25
Amir's Avatar
Amir
I just know that some numerical algorithms and schemes have numerical diffusion behavior because of their definitions, if you describe your problem clearly, I may help you.
Old   April 10, 2011, 18:44
ronen
I managed to perform LES(Smagorinsky-Lilly).
Now I would like to model species transport.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
