Problems simulating a pressure wave supercharger |
April 8, 2011, 16:12 |
Sam
I am trying to simulate the flow through a pressure wave supercharger using FLUENT 6.3. The pressure wave supercharging concept uses the engine's exhaust gases to compress the fresh air entering the engine. The flow is controlled using a rotating cell wheel, which directs the flow in a number of channels... The general process can be seen below: I have set out the problem by representing the cell wheel as a sliding strip with interfaces for each of the ports as follows: I have used periodic conditions on either end of the sliding cell section and have defined the section as a moving reference frame but when simulating, I do not seem to be getting any movement from the section. Is there a better way that I could set up this problem or is there something i'm missing! Any help would be greatly appreciated, Thanks in advance, Sam |
April 12, 2011, 11:52 |
Sam
Does anyone have any idea on how I can make the sliding boundary move translationally? I have followed similar steps to that of FLUENTs rotationally sliding mesh tutorial, but for some reason I cannot replicate this movement in my simulations.
I can provide any other information regarding the case set up if that helps determine where i'm going wrong! Thanks, Sam |
comprex, pressure wave, supercharger |
How to find the reflections of the pressure wave in pipe lines | RKR | Main CFD Forum | 0 | April 6, 2011 09:08 |
Problems with extrapolation of pressure in BC | Sergio | Main CFD Forum | 0 | July 17, 2008 10:05 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
RE: Pressure wave | tah | Phoenics | 6 | March 25, 2005 14:43 |
Has the pressure correction method problems? | X. Ye | Main CFD Forum | 17 | September 1, 1999 17:14 |
