natural convection equations in non-dimensional form |
April 8, 2011, 05:18 |
Ehsan
Rep Power: 15 |
Hi guys
I am trying to simulate a natural convection flow inside a triangular..... by fluent. How i can solve natural convection equations in non-dimensional form? How i can estimate modified material properties based only on two input parameters Pr and Ra? |
April 25, 2012, 23:21 |
studen
Rep Power: 14 |
1. in fluent you can not solve non-dimensional, everything is dimensional .
2. regarding the pr and ra, you cant give direct input, as your know it depends on viscosity, and specific heat. depends on volumetric co-efficeint, viscosity, length of the cavity, and temperature difference,you have to entre these properties in materials section and intialize, set the boundary conditions and u can see the prandtl number in contour--->contour of properties--->molecular prandtl number. |
April 27, 2012, 02:50 |
Krishna
Rep Power: 17 |
You can solve in non dimensional form in Fluent. Go to units and set every properties you encounter in your problem as non dimensional (user specified). From non dimensional equations, plug in values for coefficient of viscosity and thermal diffusivity, in your case its 1 and 1/Pr.(for forced convection problems its 1/Re). Develop a UDF for the source terms.
April 27, 2012, 02:57 |
#4 | |
Lucky
Rep Power: 66 |
April 27, 2012, 03:10 |
Krishna
Rep Power: 17 |
What I mean to say is compare the dimensional and non dimensional equations and in place of coefficient of viscosity and thermal conductivity in Fluent put the resp. coefficients 1 and 1/Pr. It is possible to solve in non dimensional form in Fluent.
April 27, 2012, 03:12 |
Lucky
Rep Power: 66 |
That still isn't non-dimensional form or non-dimensional equations. They're definitely dimensional, you just took away the units.
April 27, 2012, 03:48 |
studen
Rep Power: 14 |
i have used fluent 6.3.26 you can not change to non-dimensional form in this version their is no option available, the available options are british, si and cgs. i think they might have included non dimensional form from ansys fluent 12.1, which version are you using.
April 29, 2012, 22:06 |
Krishna
Rep Power: 17 |
Select new and add a name say non dimen to it. You have to make all the properties as non dimensional like Length, mass, time, velocity, acceleration, temperature, viscosity, thermal conductivity,..................
Also need to specify the limits of the properties like temperature between 0 to 1. |
Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
natural convection at high Rayleigh | mauricio | FLUENT | 2 | February 23, 2005 20:43 |
Approximate Mixing due to Natural Convection | Greg Perkins | Main CFD Forum | 0 | February 12, 2003 19:43 |
Mixing By Natural Convection Processes | Greg Perkins | FLUENT | 0 | February 12, 2003 19:40 |
natural convection in a sealed enclosure | James | Main CFD Forum | 4 | April 2, 2001 16:48 |
