Atributting one face temperature to another face
Old   March 28, 2011, 13:13
Question Atributting one face temperature to another face
nfspetronilho is on a distinguished road
Hello everyone!
I'm having this problem with transfering one face temperature to another (maybe it's due to my newbness).
Anyway, i'll describe the problem:
I've got a room with one heat source and i'm using a blower to move the air through the room. The blower only recirculates the air in the room.
My boundary conditions are:
-velocity inlet for the inlet and for the outlet (the outlet has the inverse module);
-the rest are walls;
-the walls for the heat source have a positive heat flux;
-the walls for the windows have a negative heat flux;
I consider that there exhists mass conservation on the system and that the temperature on the inlet is the same of the outlet.
My problem is: There exhists an evolution in the systems temperature, so, how can i transport the temperature from the outlet to the inlet?
I was thinking on using an UDF, but i don't know wich to use and how.
Thank you for your attention!
nfspetronilho is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
