March 23, 2011, 16:30 |
Time step for wind turbine analysis
Amool A Raina
Rep Power: 16 |
Hi all,
I am using a unsteady density based implicit solver for simulating the flow around a 50m radius wind turbine blade. The turbine rotates at 14 rpm. I would like to know if there is a specific way by which I could determine the time step size for my simulation. I started off with a low time step size 10^-5 and based on the convergence behavior, I kept increasing the size of the time step to 0.01. how do i know of the most appropriate time step size? Any help would be greatly appreciated! Thanks, aar |
March 24, 2011, 00:22 |
#2 | |
Raashid Baig
Rep Power: 16 |
I have this doubt too about the automatic timestep (how is it calculated) and physical time step (how it is calculated) and what is the difference between the physical and auto time scale. Raashid |
March 24, 2011, 09:29 |
#3 | |
Rep Power: 16 |
March 24, 2011, 13:28 |
Amool A Raina
Rep Power: 16 |
do u have any references for wind turbines?
March 25, 2011, 02:58 |
Rep Power: 16 |
3d wind turbine, time step size |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
HELP! time step too small? | meangreen | Main CFD Forum | 6 | May 31, 2018 10:41 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
Hydrostatic Pressure and Gravity | miliante | OpenFOAM Running, Solving & CFD | 132 | October 7, 2012 22:50 |
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
