Error in calculating non dimensional pressure gradient
Old   March 23, 2011, 03:50
Exclamation Error in calculating non dimensional pressure gradient
MANISH BHATIA
MANISHBHATIA is on a distinguished road
DEAR ALL,
I HAVE DONE SIMULATION OF FLOW AROUND PERIODIC ARRAY OF CYLINDER DIA: 0.00015 m. then i calculated pressure drop using difference in area weighted pressure at inlet cross section and mid point cross section and multiply it by 2. that total pressure drop used for calculating non dimensional pressure gradient.
but values are correct only at Re near 20- 30. its value are wrong at both low and higher Re. for ex at re =5 correct value is 14 but i m getting 1.8.
and same problem is happening for porosity 0.8, 0.9, 0.92.
kindly help
MANISHBHATIA is offline   Reply With Quote
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
how to get pressure gradient chinayu Siemens 1 May 11, 2006 09:00
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Which kind of pressure use calculating Drag? Fer Main CFD Forum 5 January 27, 2006 13:32
