Hi shell conduction parallel problem
Old   March 22, 2011, 12:29
Default Hi shell conduction parallel problem
mirion
laxwendrofzx9r is on a distinguished road
Hi Guys maybe somebody know why i can not run shell conduction model in parallel mode and I must say that in the serial is working perfectly fine for me. Also I was trying to find something more in the documentation but there is info that this model should work. Any idea what is wrong ? maybe is something with the parallel grid partitioning (is set-up automatic and have fluent12 academic)
Regards,
Dora
laxwendrofzx9r is offline   Reply With Quote
Old   March 22, 2011, 23:28
xrs333
xrs333 is on a distinguished road
Hi, Dora,
Try to setup and save the case in serial solver then read it with parallel one.
xrs333 is offline   Reply With Quote
Old   March 23, 2011, 19:33
mirion
Originally Posted by xrs333 View Post
Hi, Dora,
I was trying before (from serial to parallel ) also must say that this model is periodic maybe this is the problem?
Regards,
Old   March 23, 2011, 21:30
xrs333
Are you using DTRM radiation model or comformal mesh adaption?
Old   July 4, 2011, 08:12
Smile
mohammad
mohammad is on a distinguished road
Regards,
Dora
Hi ,
I have somewhat the same problem...when I'm using 16 CPUs (4 cnodes*4ppn). in CFX121
when I use serial mode, the model is solved with speed of 12 (iterations/hour).
when I use "Parallel" or "Distributed" it's slower..just 1( iteration/ hour).
What's the problem?
The OS is LINUX and I think I must activate the parallel processing ...if I'm true...how to do that?
Regards
mohammad is offline   Reply With Quote
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 11:26
Parallel UDF problem, hello world version pilou FLUENT 0 March 10, 2011 09:20
A Strange Problem in making Parallel (Ansys/CFX 12) a.sarami CFX 13 October 7, 2010 02:33
Parallel Run problem shhe OpenFOAM Running, Solving & CFD 1 April 27, 2010 07:52
parallel UDF problem kerem FLUENT 2 June 20, 2006 07:56
