how to perform temperature gradient on a particle (Thermophoretic Force)
Old   March 22, 2011, 09:20
Exclamation how to perform temperature gradient on a particle (Thermophoretic Force)
mu lin
wwt650420 is on a distinguished road
hi, everyone.
Now i model dpm in a turbulent flow with a significant thermophoretic force.
And just like what user's guide of fluent has introduced in 22.2.1 Equations of Motion for Particles. thermophoretic force is proportional to temperature gradient.
F_thermal force=f(dT/dx)
While in a 2D model, there are 2 directions for temperature gradient acted on a particles (as UDF manual , C_T_G(c,t)[0] and C_T_G(c,t)[1])
My Questions:
(1) How could i write a correction formulation for thermophretic force on a particle with these two temperature gradient vector?
(2) Why there is only Fx for a particle in user's guide of fluent when thermophoretic force is formed? What about Fy and Fz(if 3D case)?
(3) if any body had a UDF about thermophoretic force, please send me a copy.Thank you very much.
My email:mulin0803@sina.com or wwtmwtd@hotmail.com
wwt650420 is offline   Reply With Quote
Old   March 22, 2011, 13:36
Amir's Avatar
Amir
Amir is on a distinguished road
I don't think that you're right. in user manual F_x is just a notation and the force acts in resultant gradient vector direction. you can also check that in a simple case which has temperature gradient only in y-direction.
Amir is offline   Reply With Quote
Old   March 22, 2011, 22:21
Default how to perform temperature gradient on a particle (Thermophoretic Force)
mu lin
Maybe i know what you mean. What i have modeled is a cross flow. so for a tueb surface it is a circle, even in the flow field it is hardly to show what is the exact direction of thermophoresis. Well, if U have a better code ,please send me a copy, and i will still study and search some literatures on it.
Thank you Amir.
Old   March 23, 2011, 03:10
Amir's Avatar
Amir
I meant that you can generate a simple mesh(e.g. a cube) and perform a temperature gradient in y-direction with boundary conditions and see whether it influences the particles or not.
temperature gradient for use in surface monitor Catherine FLUENT 1 August 24, 2012 10:10
temperature normal gradient on a boundary Sandrine Main CFD Forum 2 June 10, 2009 17:34
Pressure gradient in particle simulation Mikka Main CFD Forum 0 August 5, 2007 22:55
Pressure gradient in particle simulation Mikka Main CFD Forum 0 June 30, 2007 23:16
model particle movement under magnetic force phsieh2005 Main CFD Forum 8 March 28, 2007 08:12
