Horizontal Axis Wind Turbine
Like Tree1Likes
Old   March 21, 2017, 16:50
Default Solution
  #21
Shubham Deshmukh
Shubham_SD is on a distinguished road
Hi all,
I too had a similar problem. And its has the easiest solution.
The problem occurs due to wrong projected area taken in the reference values.
Solution:
Take out projected area along the normal to the r vector (where Torque= r x Force) and divide your torque values by this projected area.
(let the reference value of Area be 1 m^2 if you are using fluent)
You may need to double or triple this torque value (according to no. of blades) if you are using periodic condition.
On how to find projected area: http://www.afs.enea.it/project/neptu...ug/node963.htm
Regards
SD
Shubham_SD is offline   Reply With Quote
Old   March 21, 2017, 16:54
Shubham Deshmukh
Hi all,
Solution:
Regards
SD
Old   May 24, 2017, 13:17
Default Cfd post processing
  #23
Patrick16 is on a distinguished road
I am simulating a non rotating wind turbine blade for HAWT. I am getting a weird graph at a given percentage of the span (coefficient of pressure vs cord length) . Several points are intersecting.
What could be the problem that cause such irregular pressure distribution?
I unable to attach sample of the graph
Patrick16 is offline   Reply With Quote
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
2D Modelling of Horizontal Axis Wind Turbine Richeom Main CFD Forum 1 April 7, 2014 18:43
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 04:13
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 09:34
OVERFLOW and Horizontal Axis Wind Turbine ntonkin Main CFD Forum 1 November 19, 2009 02:40
