Rep Power: 0 ![]() |
Hi group,
I have a question about the possibilities of Fluent. Consider you have a box filled with an alloy of 2 salts. From the outside you define a temperature that is above the phase transition temperature of the alloy, i.e., the alloy will start to melt. The question is can I model this process including the time development of the melting front as it moves from the outer surface to the core of the salt? Can I model the temperature distribution dynamically? Do I need user defined functions for this kind of simulation? Thank you very much in advance! JC |
simulation two phase closed thermosyphon | mohammad reza | FLUENT | 3 | November 1, 2016 03:58 |
flow simulation with a fixed transition point? | cfdzou | FLUENT | 2 | March 4, 2016 22:05 |
Three phase simulation of airlift reactor | Idtisak | CFX | 0 | February 22, 2008 10:05 |
multi phase simulation | Thandavan | CFX | 4 | June 28, 2006 23:29 |
time and phase averaging simulation data | prem | FLUENT | 0 | December 28, 2003 22:15 |
