Multiphase Porous Media Flow - Convergence Issues
Old   March 14, 2011, 16:47
Default Multiphase Porous Media Flow - Convergence Issues
Michael
VT_Bromley is on a distinguished road
System Description:
Two phase solid-gas flow. The sold being sand particles and the gas is air. Air is injected through a nozzle that entrains the sand particles up a ramp and the mixture hits a filter. The filter ideally filters out the sand particles which drop into a collection area while the air exits the system. A picture of this system can be seen below:
The nozzle is the square portion in the blue region on the left hand side. The end of the rectangle is the velocity inlet. The green line at the top right is where my porous media zone is (No the exact geometry used, but had a picture on hand). The pink is the sand initially and the blue is the air initially.
FLUENT Model Details:
  • Pressure-Based Solver
  • Transient
  • Eulerian-Eulerian Model
  • k-epsilon model
Porous Media Zone
Relative Velocity Resistance Formulation
Porosity: 0.8
  • Air
    • Viscous Resistance (Direction 1): 4.76E10
    • Viscous Resistance (Direction 2): 4.76E10
    • Inertial Resistance (Direction 1): 4.79E-6
    • Inertial Resistance (Direction 2): 4.79E-6
  • Sand
    • Viscous Resistance (Direction 1): 4.76E13
    • Viscous Resistance (Direction 2): 4.76E13
    • Inertial Resistance (Direction 1): 0.00479
    • Inertial Resistance (Direction 2): 0.00479
Boundary Conditions
  • Velocity Inlet ("Nozzle") - 345 m/s
  • Outlet (Top of Porous Media Zone) - 0 ga Pressure
Solution Methods
  • Scheme - Phase Coupled SIMPLE
  • Gradient - Least Squares Cell Based
  • Momentum - First Order Upwind
  • VF - First Order Upwind
  • Turbulent KE - First Order Upwind
  • Turbulent Dissipation Rate - First Order Upwind
  • Transient Formulation - First Order Implicit
Solution Controls
Under Relaxation Factors
  • Pressure - 0.3
  • Density - 1
  • Body Forces - 1
  • Momentum - 0.5
  • Granular Temperature - 0.2
  • Turbulent KE - 0.8
  • Turbulent Dissipation Rate - 0.8
  • Turbulent Viscosity - 1
Problem
I have solved this case without the porous media zone and just using a pressure outlet. My issue was that particulate was flowing out of the outlet and not being collected as desired. The case runs fine until the Volume Fraction becomes anything but 1 (all air) at the porous media zone. An example of the residuals up until this point is shown below:
The volume fraction of air at this point is shown below. The rectangle section at the top right is my porous media zone:
Then I get to this point:
And the residuals begin to flat line or really struggle to converge.
What has been tried to remedy the problem:
  • variable time steps
  • messing with the Courant number
  • second order discretizations
  • adjusting the porous media parameters
  • under-relaxation factors
All to no avail.
I did get it converging for a little while but then this happened:
And it diverged very soon after.
Any ideas on what I can try? Do all of my settings look correct?
Thanks!
Mike
VT_Bromley is offline   Reply With Quote
Old   March 17, 2011, 16:09
Michael
I have still been working at this to no avail. I doubt my values for the viscous and inertial resistance though. I used a orifice style flow bench to find the pressure drop versus velocity curve. I then fit the curve with a quadratic function and used the coefficients to solve for alpha and C2. However, I'm unfamiliar with "typical" values and am not sure that it is right. Here is my data and the plot. The filter is just a coffee filter so I wouldn't expect it to be too restrictive.
Old   March 18, 2011, 02:01
Byron Smith R J
byronsmith is on a distinguished road
hai
wats the boundary condition imposed on the filter material. u need to create a bc such that only air passes through and sand is retained
byronsmith is offline   Reply With Quote
Old   March 18, 2011, 11:56
Michael
Originally Posted by byronsmith View Post
hai
As far as I know there is no option for such a boundary condition; hence the use of the porous media. If I'm incorrect please let me know.
Old   March 21, 2011, 00:23
Byron Smith R J
to selectively transport one component u will have to write UDF
Old   March 23, 2011, 11:38
Michael
That is one method, but a porous media zone should work as well as you can apply different resistances to each phase. Therefore I apply a large viscous and intertial resistance to the solid phase to prevent it from passing through the porous zone.
I did manage to get the problem to converge and prevent the solid phase from flowing through the porous zone. I removed the visous resistance for air as this should not really be a factor.
It is working great, but I have it currently set as a variable time step and to converge it is stepping at 1e-8 seconds. As you can imagine with about 200 iterations per time step this solution is taking a LONG time.
Does anyone have any hints/tips to speed up convergence in this case?
Thanks,
Mike
Old   January 5, 2020, 13:53
Okwoche James
JAMESOK is on a distinguished road
Please, how did you arrived at the value of the viscous and inertia resistance?
I really need to find values for the inertia and viscous resistance of fired pottery clay and sand as well.
anyone who can help, please?
Thanks in advance
James
JAMESOK is offline   Reply With Quote
Old   May 14, 2020, 17:34
roshan
roshanak.rabiee878 is on a distinguished road
Hi
if you want to use the pressure-velocity curve for estimation of alpha(m-2),C2(m-0 (two coefficients for porous media) you have to divide pressure by depth of packing the use slope to evaluate alpha and c2.
dP/H=alpha*mu*U+(0.5rho*C2*U*U)
roshanak.rabiee878 is offline   Reply With Quote
Old   May 30, 2024, 03:59
Liam Jose
hailejose is on a distinguished road
Thanks,
Mike
did you find any way to speed up the time and reach appreciable convergence with the porous media approach?
hailejose is offline   Reply With Quote
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
Can LES be used in porous media flow? Jin Main CFD Forum 0 October 19, 2006 09:50
Simulation of Porous Media Flow Sharad Dugad FLUENT 0 December 24, 2001 02:57
Help :Porous media flow Wole CFX 7 August 30, 2001 21:32
