Nusselt number variation over a ribbed surface |
March 8, 2011, 15:48 |
Avinash
Rep Power: 15 |
I am Avinash. I am working on "Heat transfer analysis in a turbine blade cooling passage of trapezoidal crossection" Boundary conditions: Inlet-Mass flow Outlet-Pressure outlet Two opposite surfaces of the passage are given constant heat flux and are of the same value. The surfaces have 45 degree ribs to enhance heat transfer coefficients. Problem: I need to obtain the variation of nusselt number over the heated surfaces..therefore a central line was drawn over each of the surface and the surface nusselt number was plotted.....but unfortunately i am not getting realistic values of the nusselt number......lot of difference between the expt and cfd values. Convergence criteria was met. Realizable k-epsilon model was used. Can somebody pls provide suggestions in getting the suitable values of the nusselt number??? Regards Avinash |
March 9, 2011, 12:57 |
Yogesh Patil
Rep Power: 17 |
What is the value of y+. For your kind of analysis it should be less than 1. Also try using k-omega SST instead of K-epsilon.
Regards, yogesh |
March 10, 2011, 13:09 |
Avinash
Rep Power: 15 |
@yogesh
my y+ value is 3.7...........i will use the sst k-omega model and see if i can get accurate values..your reply has been helpful....thank you very much |
Airfoil Average Nusselt Number calculation | y2k_o__o | FLUENT | 6 | March 3, 2011 08:37 |
Local Nusselt Number | rohangulavani | FLUENT | 0 | July 6, 2010 08:03 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
Nusselt Number | abir | FLUENT | 1 | August 30, 2009 04:48 |
how to calculate Nusselt number? | prayskyer | Main CFD Forum | 0 | June 17, 2006 21:57 |
