Problems with BCs in muliphase flow with water falling from a reservoir
Old   March 8, 2011, 09:36
Default Problems with BCs in muliphase flow with water falling from a reservoir
Paul Levold
Paul_l is on a distinguished road
I've been doing the VOF tutorial in the Fluent manual and now I'm trying to modify it to my likings. In the tutorial the flow is driven by a time dependent velocity from the inlet, but I want to do a simulation where the water is falling due to gravity. What I've done is:
-Introduced gravity in positive x-direction (been doing some tests and I think the gravity is fine)
-Made the inlet BC a pressure inlet with 0 gauge pressure
When I patch the nozzle with water and run the simulation, the only thing that happens is that a small strip (the first row of cells) becomes air. It does not seem to be much more movement, neither at the top of the water column nor at the bottom where the water should flow out.
I've also tried patching a small area below the nozzle with water. If the vertical sides of this water column is in contact with air and not the wall, this water falls down as expected. The water in the nozzle however stays inside now as well.
Have I completely misunderstood what kind of boundary conditions I should use?
Paul_l is offline   Reply With Quote
Old   March 10, 2011, 14:57
mohsen
momech is on a distinguished road
hi dear sir.
if the nozzle diameter is too small,i think the physics of problem is such that no water falls down due to gravity,because of adherence!
momech is offline   Reply With Quote
Old   March 11, 2011, 05:59
Paul Levold
Thank you! That is a very good point. I ended up making a grid where the top of the nozzle and the area below is connected so air can flow around. That among with a slightly larger scale and variable time stepping seemed to work well.
Here's a screenshot of my (axisymmetric) grid if somebody is have the same problem:
Need help in counter flow heat exchanger problems satheeshmech FLUENT 0 September 29, 2010 09:48
Best settings for solar car external flow problems kdrbrk Main CFD Forum 0 July 16, 2010 03:18
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
water droplet flow F.K. CFX 0 April 27, 2004 03:36
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
