Divergence detected in AMG solver : k
Old   March 8, 2011, 05:57
Default Divergence detected in AMG solver : k
Tarik Bennani
littlebroca is on a distinguished road
hello,
I am currently trying to simulate a water flow into a nozzle for a atomisation. It's an internal flow with very small dimensions.
I am using the VOF method, with the water flow going through the air. Transient flow and turbulent (Realizable k-epsilon) are my conditions.
I have a Reynolds (for the Inlet) of about 3500.
I used a velocity inlet and pressure outlets. I used the turbulent intensity (that i calculated as a 5,7%) and turb viscosity ratio (that is around 12%)
My time step is 5e-7s, but my calculation always seem to diverge. (It says for the initialization that the courant number is around 3, but it gets very quickly to a higher number than the 250 bar over which Fluent doesn't continue)
Do i just adjust manually the under relaxation factors ? Is there may be something that some of you might help me with ?
Thank you in advance.
Tarik.
littlebroca is offline   Reply With Quote
Old   May 13, 2011, 02:31
J.-H. Wang
f0208secretx is on a distinguished road
I have encountered a similar problem... adjusting the under relaxation factor doesn't seem to work on me.
f0208secretx is offline   Reply With Quote
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 12:34
ERROR: divergence detected in AMG solver black mamba Main CFD Forum 0 April 19, 2010 16:15
divergence detected in AMG solver !!! yansheng FLUENT 0 September 27, 2007 12:22
DIVERGENCE detected in AMG solver ENTHALPY MANOJKUMAR FLUENT 2 December 25, 2005 10:54
divergence detected in AMG solver: Shekhar Jain FLUENT 1 September 18, 2003 10:31
