Dynamic mesh: moving a wall along X and Y axis..Please HELP
Old   March 7, 2011, 06:30
Default Dynamic mesh: moving a wall along X and Y axis..Please HELP
noa
anonymous
noa is on a distinguished road
My model is a 2D rectangular channel. I am able to move the upper and lower walls of the channel along Y axis (using UDF, DEFINE_GEOM). However, when I try to move these walls also in the X axis it says error.
Is it possible to move a wall along X and Y directions using UDF or any other method?
noa is offline   Reply With Quote
Old   March 7, 2011, 09:07
Amir's Avatar
Amir
Amir is on a distinguished road
Hi,refer to:
http://www.cfd-online.com/Forums/fluent/84749-moving-wall-boundary-condition.html
Amir is offline   Reply With Quote
Old   March 7, 2011, 10:51
xrs333
xrs333 is on a distinguished road
Moving along the wall surface itself should not be modeled with dynamic mesh, instead it may be simulated with boundary condition of the wall.
xrs333 is offline   Reply With Quote
Old   March 8, 2011, 03:58
noa
anonymous
I am using udf to move the upper and lower walls . I tried to move these walls along the X axis using boundary condition(using moving wall), but when I do that it just take the udf and ignore the boundary condition.
Old   March 8, 2011, 04:00
noa
anonymous
Hi Amir,
I can't open this link you sent me.
Old   March 8, 2011, 10:48
noa
anonymous
Thank you, I opened it.
However my 2D channel is expanding (which I already did) and moving along X axis. How do you do it both???
Old   March 8, 2011, 10:56
Amir's Avatar
Amir
if you have a function of boundary nodes changes with time, you can do that with implementation of smoothing tool in dynamic mesh.
Old   June 15, 2012, 08:38
Default help
dhu
urmi
dhu is on a distinguished road
I am new to CFD online and recently started working with fluent...can anybody help with my model of a liquid in rectangular tank which has a half-circular patch at its base of a second fluid? now I want to move the left and right wall opposite to each other (inwards) and see the effect on the second fluid...but with moving wall boundary condition along +ve and -ve xdirection,the resultant vectors doesn't show any such motions...
please suggest the boundary condition and the model that should be used in this case( I was using VOf)
dhu is offline   Reply With Quote
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 05:27
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Dynamic mesh, wall motion Giuseppe FLUENT 9 January 20, 2006 12:02
