March 6, 2011, 00:13 |
water freezing...
Hi all,
I am the beginner of Fluent. I am doing a project of water freezing process. I get some problems on fluent set-up, hope someone can help me, thanks ! Case: Natural convection of water in heated cavity 2 vertical walls are isothermal and the temp. are kept at 283K and 273K. All remaining walls are assumed to be adiabatic. Questions: 1. It is natural convection, do I need to select solidification and melting function in this case? As I tried 2 cases with and without S&M function, I still got same result. 2. Is it correct if I set 283K and 273K at thermal temp. of 2 vertical walls? 3. If the wall is adiabatic, I need to select the heat flux and set it to zero,right ? 4. If modelling of steady- state natural convection of water in a heated cavity, it means the iteration doesn't depend on time(not transient),right? Thanks a lot! Regards, nicnic |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 08:15 |
A question about freezing of supercooled water. | sunnypart | FLUENT | 0 | November 5, 2004 05:38 |
Separation phenomenon of water, droplet and air | Raymond | CFX | 0 | July 9, 2004 23:59 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
