Not able to mesh a helix with boundary layer using gambit
Old   March 5, 2011, 12:29
Default Not able to mesh a helix with boundary layer using gambit
rohitjvbibin
rohitjvbibin is on a distinguished road
I have a model of a helix with rectangular crossection. I have applied boundary layer to the four required faces using the parameters below. After that i applied the edge mesh and face mesh. When applying the face mesh face 4 and 12 of the geometry contains 4 skewed elements. If i continue further I am sure to end up with a very bad mesh.
The parameters are:
SOFTWARE: Gambit 2.3.6
Boundary Layer
First Row: 0.001
Growth Factor: 1.2
Rows: 2
Depth: 0.0022
Internal Continuity: ON
Wedge Corner Shape: ON
Transition Pattern: 1:1
Faces: face 1,2,4 and 12
EDGE MESHING
Interval Size: 0.5
FACE MESH
Tri-Pave
Interval Size: 0.5
The file is located at http://www.sendspace.com/file/rb4yyq
Kindly help me out with this project. I need it as soon as possible.
rohitjvbibin is offline   Reply With Quote
Old   March 7, 2011, 05:40
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
go to examine mesh and check where are skewed cells.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Not able to mesh a helix with boundary layer using gambit rohitjvbibin ANSYS 0 March 5, 2011 12:27
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
Boundary Layer with Tet mesh Josh FLUENT 0 February 9, 2007 02:40
Gambit: face mesh starts at edge, not boundary lr Chris Bailey FLUENT 0 December 5, 2005 14:50
help for Gambit: 2 edges + 1 boundary layer Peter FLUENT 0 August 9, 2002 20:41
