species transport model or mixture model?HELP
Old   March 4, 2011, 19:23
Default species transport model or mixture model?HELP
zohreh
zhhjll is on a distinguished road
Hi,everybody
now ,i am simulating two liquid_solid mix on a membrane in Fluent 6.3.26.one is water ,the other is ptotin(fine solid). Flow patternon the membrane is turbulence.As far as i know,"mixture model "was used to simulate liquid-liquid mix which caused by "turbulance",and "species transport model "was used to simulate liquid-liquid mix which caused by "diffusion".
But "turbulance" and "diffusion" are both occured in my problem which is a liq_solid mix ,so which "mixture model "should i choose? species transport model or mixture model?
or the exsited fluent model cann't solve my problem?
thx in advance!
zhhjll is offline   Reply With Quote
Old   March 5, 2011, 09:06
Amir's Avatar
Amir
Amir is on a distinguished road
Hi zohreh,
if you have relatively low stokes No., you can simply use a scalar transport Eq. that contains both convective and diffusive terms.
regards,
Amir
Amir is offline   Reply With Quote
Old   March 5, 2011, 09:27
zohreh
Hi dear Amir
thank u for your answer! can you please answer my question , what kind of model can help me in this problem, speaces or mixture model??
I have a dilute mixture of liq-solid which the concentration of solides is low!!
Old   March 5, 2011, 16:27
Amir's Avatar
Amir
as I said before it depends on stokes No. and also concentration.
for solid-liq. mixture with low concentration DPM is recommended instead of mixture method.
but if your stokes No. is relatively low, you can use species transport that is special case of scalar transport eq. that I prefer to use scalar transport eq. directly.
at last for implementation of these you should calculate diffusion coefficient of solid particles before.
hope that help you.
Multiphase model and species transport Reginaldo Cotto FLUENT 1 June 6, 2024 05:02
vof+solidification melting model + species transport arou FLUENT 0 July 4, 2010 14:38
species transport model soundar FLUENT 1 February 3, 2005 15:13
Surface reactions in Species transport model Karthick FLUENT 0 May 26, 2004 06:24
Species Transport model Vs discrete phase Karthick FLUENT 0 April 27, 2004 03:23
