small doubt with fluent
Old   February 28, 2011, 04:40
Default small doubt with fluent
iņigo
iņigo is on a distinguished road
Hello. I am working in the simulation of a ductile iron cube submerged in a molten salt bath.
Obviously, the cube and the salt bath are at different temperatures, but I can't figure out how could I implement it; if I use the 'initialize' command, the two volumes are at the same temperature, and using the 'boundary conditions' command doesn't help either, because it only puts the wall at the requested temperature (as expected).
So, my question is: is there any way to impose two different temperatures to two volumes before starting the simulation?
Thanks in advance
iņigo is offline   Reply With Quote
Old   February 28, 2011, 10:13
Amir's Avatar
Amir
Amir is on a distinguished road
you can do that by patching method.
Amir is offline   Reply With Quote
Old   February 28, 2011, 12:36
Diego Simón Davila
DiegoS is on a distinguished road
I've made a little video for you:
http://www.youtube.com/watch?v=iK3gShc_wsY
I've patched using a register, but if the cells you want to patch are in a different volume zone, you can better use that (check the Patch window).
Cheers
DiegoS is offline   Reply With Quote
Old   February 28, 2011, 14:04
iņigo
Thank you!that works wonders
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
doubt on Patch option in FLUENT raghav FLUENT 0 November 4, 2008 23:33
