Parallel fluent problem
Old   February 24, 2011, 06:41
Default Parallel fluent problem
salvoblack is on a distinguished road
Hello everyone,
I am using parallel computing with fluent with 4 processors.
In particular I am studying an airfoil with Spalart-Allmaras turbulence model.
The strange thing is that depending on the number of processors used (1.2 or 4), when I go to perform in the "execute commands" command "extract airfoil cp etc. .." I get different points of my profile.
For example, by making a calculation with two parallel processors, the CP extract is 576 points, but if I use 4 processors becomes 582 points.
Someone suggested I change something in the 'execute commands "
Can you help me???
thanks a lot
salvoblack is offline   Reply With Quote
Old   February 27, 2011, 02:36
xrs333
xrs333 is on a distinguished road
That's because of different patitions created with different number of processes in case one of the partition interfaces across the face zone from which you extract the profile. May you try to partition the domain manually to see if that happen again.
xrs333 is offline   Reply With Quote
Old   March 2, 2011, 11:24
I did as you say and I have no problem partitioning manually.
But since I have to export the pressure coefficient by "execute commands", there is a command that takes account of the parallel exporting only the nodes so effective??
Parallel fluent not using all processors specified Paul FLUENT 18 October 26, 2023 04:54
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 11:26
Parallel processing problem with Fluent Harish FLUENT 3 February 8, 2011 10:49
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 18:11
UDF in parallel version of fluent yobee FLUENT 2 August 5, 2004 01:36
