February 23, 2011, 05:02 |
number of partitions
henry clarke
Rep Power: 17 |
Hi all,
how many partitions should I use for parallel processing with a quad-core computer? I have selected 4 as this appears to be the default, but when I view the partitions this creates 4 partition interfaces ie. 5 segregated areas. This being the case, should I select 3 partitions so that there is one section of the grid being processed in each core? Thanks |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 11:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
