Low-Reynolds k-eps models
Old   February 17, 2011, 22:46
Default Low-Reynolds k-eps models
p_agoodboy is on a distinguished road
Hi everybody,
Anybody knows if it is possible to use low-Reynolds k-eps models in Fluent?
To clarify, in low_Re models the coefficients C_mu, C_eps1 and C_eps2 are modified based on flow characteristics or the distance from wall (different approaches in different models), and two source terms are also added to k and eps transport equations.
To summarize, I wanna know if it is possible to employ user defined coefficients rather than constant ones in Fluent and add new terms to the turbulence transport equations.
p_agoodboy is offline   Reply With Quote
Old   February 18, 2011, 01:48
alastormoody11 is on a distinguished road
you can change the constants used for the k-e model using a journal file if you want after each time step or iterations if you want. To get the basic framework you can record a journal file where manually change the constats. Using this as a reference you can add your own functions to the code to change it between time steps.
I do not think that you can add source terms to the existing equations though.
If it is a low- Re flow you could also use the k-w model.
alastormoody11 is offline   Reply With Quote
Old   February 18, 2011, 21:48
Thank you for your help.
Could you please give me more explanation about journal files? or tell me where can I obtain more info.
In fact, I should decide whether Fluent is capable enough for my problem or I better proceed to an in-house code. It is actually a determining step for my PhD thesis.
How much using a journal file can increase computational cost? (I mean solution time)
I should model a rather complicated mixed convection turbulence flow and I need to examine different turbulence models so it is important for me to have enough freedom in using software.
Old   February 18, 2011, 22:05
I should add that the coefficients are functions of position too, so it is not enough to change them in each time step but in each cell.
k-epsilon model, low reynolds, turbulence model
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 12:42
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 15:39
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 17:38
Turbulence Models for very low Reynolds Numbers Sudhi CFX 1 March 2, 2007 19:03
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
