February 16, 2011, 10:55 |
Interface-Wall IDs
nassim swlyman
Rep Power: 17 |
hi all
in my grid which is made by gambit I have 2 circular interfaces,the problem is: when exporting the mesh to Fluent you will find Interface-Wall IDs on some parts of the interfaces, this means fluent will consider these parts as walls not as interfaces. the main note is: I have no unconnected faces, edges,or vertices in my grid,and if you tried to connect the edges,Gambit will connect them,this means Gambit is recognizing that these 2 (for examble) edges are identical and this is expected because the second interface was made by copying the first circle using zero for transition vector, now fluent gives Interface-Wall IDs and if zoom in the problematic area you will see the 2 edges not identical????????????? I've tried to use Tgrid and I had the same problem can anyone help me PLZ Is this some thing can be related to different tolerance values between Gambit & FLUENT??? |
February 19, 2011, 19:04 |
nassim swlyman
Rep Power: 17 |
circular interface, interface-wall ids, interfaces, meshing |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 06:36 |
Influece of wall velocity in the main flow | marvin | CFX | 0 | March 22, 2008 03:05 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
