February 14, 2011, 18:55 |
Cl-alpha, 3d airfoil problem.
Levon
Rep Power: 15 |
I am trying to determine dCl/d(alpha) for a 3d airfoil however Cl is barely changing (0.38-0.42) as I vary alpha (0-10 degrees), any help?
I only need preliminary results so my mesh is fairly coarse. Thanks. |
February 15, 2011, 02:07 |
Rep Power: 16 |
If you are reporting Cl from the monitors, are you sure your reference values are correct?
If that's not it, I'd try refining your mesh first. |
February 15, 2011, 09:29 |
Levon
Rep Power: 15 |
My reference values are good, Fluent is simply underestimating the force produced by the airfoil as it changes angles. I also forgot to mention that my first mesh refinement did not fix the problem.
I am very closely following the 2D wing tutorials, at this point my wing is just a 2D airfoil that has been extruded. |
airfoil, alpha, angle of attack |
Problem Meshing Airfoil | erodv | OpenFOAM | 12 | January 11, 2012 17:46 |
Problem with boundary condictions in an airfoil | bego | OpenFOAM Running, Solving & CFD | 0 | September 22, 2010 05:56 |
cyclic BC from gambit to openfoam for cascade airfoil problem | maverick | OpenFOAM | 0 | April 13, 2010 15:18 |
[FloWorks] Request advice for an airfoil calculation problem | Bogey Jammer | Main CFD Forum | 0 | September 29, 2009 17:06 |
problem specifying alpha at inlet during a parallel run | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | August 13, 2009 08:23 |
