February 11, 2011, 19:06 |
Flow over a cylinder.
Ugly Kid Joe
Rep Power: 16 |
I am simulating a 2-D flow over a stationary cylinder to determine the Cl and Cd over the cylinder. My question is in the lift coeff formula i.e Cl=F/(0.5*density*U^2 *Area), the area is the projected area i.e length*diameter or the surface area (2*pi*radius*length) ??? Also what values should I put for Depth, Enthalpy, Ratio of Sp. heat in the reference values tables ??? Is the depth same as diameter of the cylinder ??? |
February 14, 2011, 02:43 |
Maxime Perelli
Rep Power: 41 |
http://en.wikipedia.org/wiki/Lift_coefficient
check especially 2d section. Formula for Lift coefficient doesn't involve Enthalpy etc.. so you are not suppose to set those parameters
In memory of my friend Hervé: CFD engineer & freerider |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 12:47 |
Moving a Cylinder in cross flow after solving Dynamics equations of motion | maruthamuthu_venkatraman | OpenFOAM | 1 | November 19, 2009 14:55 |
Flow over a flat plate & Flow over a cylinder | cfdxue | Main CFD Forum | 0 | November 27, 2007 00:26 |
Anybody knows smth abt the flow around a cylinder? | Wenxuan | Main CFD Forum | 3 | March 20, 2007 17:19 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 15:32 |
