Moving Wall Boundary Condition
Old   February 8, 2011, 03:43
Default Moving Wall Boundary Condition
Morteza
neo_mor is on a distinguished road
dear friends
Is there any udf for moving wall with time dependent velocity on the web?
i need it ASAP.
thanks,
neo_mor is offline   Reply With Quote
Old   February 8, 2011, 04:49
Amir's Avatar
Amir
Amir is on a distinguished road
Hi Morteza,
I previously wrote a UDF for rotating wall. theta as a function of time, for other types of wall motions you can change some lines of that :
#include "udf.h"
#include "stdio.h"
#include "math.h"
// rotation theta=f(t)
DEFINE_GRID_MOTION(eye,domain,dt,time,dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real dtheta,a,b;
int n;
SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v=F_NODE(f,tf,n);
if (NODE_POS_NEED_UPDATE (v))
NODE_POS_UPDATED(v);
dtheta=......; // compute dtheta as a function of dtime (differentiation)
a=cos(dtheta)*NODE_X(v)-sin(dtheta)*NODE_Y(v); // rotation tensor
b=sin(dtheta)*NODE_X(v)+cos(dtheta)*NODE_Y(v);
NODE_X(v)=a;
NODE_Y(v)=b;
end_f_loop(f,tf);
Amir is offline   Reply With Quote
Old   February 8, 2011, 04:56
Default Thanks
Morteza
Dear Amir
thank u for your help.can you explain differences between moving wall and grid motion?
Old   February 11, 2011, 04:36
Amir's Avatar
Amir
Hi Morteza,
you can hang this UDF where ever you want, obviously your wall also has grid points and they can move. but notice that you can use remeshing and smoothing options in your case.
Old   February 12, 2011, 05:00
Morteza
thank u Amir,
Consider a tank that contains water about its half height.
and the whole tank begins to move with time dependent velocity.
in this case i should use moving mesh or moving wall?
tanks in advance.
Old   February 12, 2011, 09:58
Amir's Avatar
Amir
Hi Morteza,
of course you should use moving mesh without deforming or smoothing or... .
if velocity was constant, you could easily use moving reference frame but in your case the above UDF works. just hook it to all of your zones like wall,interior,... except fluid ones.
Old   February 15, 2011, 05:02
Morteza
Hi Amir
Thanks for your help.i will check it and whether i have problem i will inform you.
thanks again.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 10:28
thermal boundary condition at coupled wall gokul patil FLUENT 2 June 19, 2014 06:07
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
