Patch a bubble inside turbulent flow
Old   February 4, 2011, 05:54
Default Patch a bubble inside turbulent flow
Helmi
Helmi is on a distinguished road
Hi there!
I am working on a U-type static mixer (Reactor) with turbulent flow regime inside the reactor. The aim is to investigate study the behavior of fluid particles inside turbulent flow regimes using LES/VOF technique. I wonder to know if anyone has experience on the patching of fluid particles inside turbulent regimes. I have already done with the main flow field using LES model.
Do I need to patch pressure inside the bubble? What about velocity field? I as I got FLUENT has default values for velocity and pressure fields inside the second phase.
Many thanks
// Arash
Helmi is offline   Reply With Quote
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
Artificial jump in turbulent quantities across cyclic patch in slice of 360 deg flow natrask OpenFOAM Running, Solving & CFD 0 March 26, 2009 11:21
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
