February 4, 2011, 05:14 |
error in exporting mesh..urgent help needed
sudeep
Rep Power: 16 |
I am a new user of Fluent. Currently I`m using Fluent 6.3.26 and GAMBIT 2.3.16. I`m modeling a supersonic nozzle problem using Solver FLUENT 5/6. Unfortunately, I got this error " ERROR: volume sphere1 has higher order elements and cannot be exported to fluent 5 format. the mesh file was not created."
Please help me. Thanks in advance! |
February 4, 2011, 05:29 |
Maxime Perelli
Rep Power: 41 |
Did you increase, in Gambit, the value of nodes in Set Volume Element Type?
If you did: set it at lowest value. > default set "MESH.NODES.HEX" numeric 8
In memory of my friend Hervé: CFD engineer & freerider |
February 4, 2011, 08:57 |
sudeep
Rep Power: 16 |
Thank you but its a 2D mesh..I have attached a pic of the meshing.
February 4, 2011, 09:39 |
Maxime Perelli
Rep Power: 41 |
Correcting the volume element type will also correct face et edge element type (automatically)
But did you increase, in Gambit, the value of nodes in Set Volume Element Type , Set Face Element Type or Set Edge Face Element Type?
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 01:27 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
Mesh generation software is needed | H.Dou | Main CFD Forum | 12 | May 4, 2011 16:20 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
