Time step in Transient simulation
Old   February 2, 2011, 17:31
Default Time step in Transient simulation
sunny
sandisk is on a distinguished road
how should we calculate time step in case of transient simulations ? I am simulating slurry flow (water and sand) in pipes ? Has anyone done simulation of slurry flow ? Had some queries ? Thnx.
sandisk is offline   Reply With Quote
Old   February 2, 2011, 21:56
Real Name :)
ComputerGuy is on a distinguished road
In transient simulations, the time step is set, not calculated. A rule of thumb is that if your transient simulations are converging in 5-7 time steps (after the initial few, which may take slightly more), your time step is small enough.
Two phase (solid-liquid, solid-vapor) transport of granular solids can definitely be modeled in Fluent. The appropriate drag law is important, as is the characterization of the type (mono-disperse, poly-disperse) of particles you're flowing.
ComputerGuy
ComputerGuy is offline   Reply With Quote
Old   February 3, 2011, 00:55
sunny
Thanks for the reply. I am trying to simulate water sand slurry using Eulerian and Mixture model. Do we have to patch the initial sand fraction before iterating ? I am trying both the models.
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
time step and iterations in steady state problem using transient solver jing113cn FLUENT 2 January 15, 2010 04:18
transient behavior dependent on time step Fab Main CFD Forum 2 May 29, 2008 12:38
time step for unsteady film cooling simulation Janendra Telisinghe FLUENT 0 December 11, 2007 07:14
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
