Can I use turbulent model to solve a laminar flow?
Old   January 30, 2011, 23:16
Default Can I use turbulent model to solve a laminar flow?
Nik
nikhil is on a distinguished road
I am handling a transient case in which flow regime changes from laminar to turbulent in a non periodic fashion. There are shifts of laminar and turbluent regime in my case
If i select any turbulent model for this case, Will it produce correct results when the flow is in laminar regime?
Thanks,
Nikhil
nikhil is offline   Reply With Quote
Old   January 31, 2011, 17:14
David Stanbridge
swiftaircraft is on a distinguished road
This will not produce the correct results. You need to set up a separate zones where you have laminar flow.
swiftaircraft is offline   Reply With Quote
Old   January 31, 2011, 17:26
Nik
Well, Flow in the domain is transient. (Inlet velocity has period profile of multiple sines and cosins). Hence, sometimes entire flow is in laminar regime and sometimes (entirely) in turbulent regime.
Therefore, i am sure whether separation of zone would work in such case.
I am thinking about writing an UDF that will turn on/off the turbulence model depending upon the Re.
I just wanted to know, Is there any other better way to do that?
Old   January 31, 2011, 20:18
DoHander is on a distinguished road
Use a transition model, in Fluent 12 and 13 you have two models that can handle transition from laminar to turbulent flow.
DoHander is offline   Reply With Quote
Old   February 1, 2011, 04:33
David Stanbridge
nikhil I agree with DoHander. Also the use of a UDF to turn features on and off is in my experience bad as you lose many features of the flow. Namely in turning off turbulence based on Re you do not see the transition zone.
Old   February 1, 2011, 11:42
Nik
Thanks guys.
I will check the transition model.
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 23:55
LES of a turbulent channel flow stays laminar liu OpenFOAM Running, Solving & CFD 2 May 27, 2010 14:53
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 14:40
laminar and turbulent flow over a single airfoil. Pablo Cornejo FLUENT 0 August 30, 2005 18:57
how to model transition laminar to turbulent? james Main CFD Forum 0 October 1, 2003 04:16
