Multiphase Convergence Problem using VOF in ANSYS 13
Old   January 27, 2011, 19:35
Default Multiphase Convergence Problem using VOF in ANSYS 13
Farhan
itsuetian@hotmail.com is on a distinguished road
Hi all,
I am Currently working on the Project Called Hydroplanning using Multiphase (Air and water) using VOF Method.My basic goal is to find the Lift and drag forces of the Air Plane Landing wheel which is moving in radial direction and between the ground which contains layer of the water 2 cm thick.Now ground Air and Water all are moving with Same Speed. .I have two fluid here one is Air and the other is Water.But the Problem is that my Solution is not getting Convergence.I have run it for days and days and it goes on without getting Convergence.So please tell me how to get that.What i did is
1-Created A tyre of .60m dia.
2-Created Enclousre arround it.
3-I keep the tyre 2cm from the ground(that is the layer of water)
4-Then i did Meshing using Patch conforming Method.
5-I did Name Selection.I Selected only one inlet for both Air and Water.
6-In Setup i Selected VOF/Implicit...
7-Selected boundary Conditions
8-i Selected very Short time Steps of .00001 and No of time Steps 1000.
I really apprciate your feed back.
Regards,
Noni
itsuetian@hotmail.com is offline   Reply With Quote
Old   January 28, 2011, 03:22
k.baker's Avatar
Khalid Baker
k.baker is on a distinguished road
May u send illustrated plot for your geometry and BC to get better understanding of your problem.
k.baker is offline   Reply With Quote
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 08:05
Convergence problem for P1 & Energy HP FLUENT 5 May 21, 2005 16:01
convergence problem limseokmin FLUENT 3 November 14, 2004 13:43
Convergence problem Praveen FLUENT 0 September 15, 2000 07:34
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 14:43
