January 26, 2011, 16:35 |
User Defined Profiles, Swirl, Velocity Inlet
teri
I've been trying to simulate the flow in a domain consisting of a large cubical volume with a channel in the bottom that is at some angle to the flow. The channel stretches from the inlet to the outlet. I expect the flow in the channel to eventually reach something like helicoidal flow. Because I want to know something about the streamlines of the flow when it is fully developed, I have been running the simulation with a uniform velocity inlet, and then writing the outlet velocities and turbulence parameters to a profile file, then I have been using these as part of a user defined profile for the inlet of a subsequent run.. repeat, repeat. I noticed that in each run, the flow would begin in the x-direction (normal to the inlet) and then begin to develop into a helicoid. I read that when using cartesian coordinates for a velocity inlet boundary condition, Fluent dots the velocity profile with the normal, which explains why my y and z velocities are kind of getting washed away, however I was wondering if there is any way around this? I've tried saving the velocities in cylindrical coordinates (v_theta should allow some "swirl", right?), however then my results are really nonsense, and the simulation doesn't converge. Any insight to a better way to initialize swirl-like flow in a non-symmetrical volume, or any other help would be greatly appreciated. If I wasn't clear or if you need more information, please don't hesitate to ask, first time posting here, it's hard to spell this stuff out! Thank you. |
profiles, swirl, udf, user defined, velocity inlet |
Steady pipe flow mean velocity higher than inlet velocity | anita | OpenFOAM Running, Solving & CFD | 7 | September 25, 2012 06:35 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
Pressure Inlet Velocity | prapanj | OpenFOAM | 11 | June 23, 2009 12:15 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
user subroutine of inlet boundary | raymond | Siemens | 4 | December 6, 2001 06:44 |
