Fluent Temperature Profiles
Old   January 24, 2011, 14:34
Default Fluent Temperature Profiles
anonymous
jcd84 is on a distinguished road
Hi I'm working on modeling 2-d bouyancy induced air flow (natural convection) using the ideal gas law for density and running a transient simulation to steady state.
For temperature boundary conditions on surfaces, I created *.prof files with several points matching the surfaces of the mesh. I loaded them and set them to be the temperature boundary condition for the appropriate surfaces. I set interpolation to "least squares."
I created point surfaces in the model to match each point in the temperature profile files. When I run the simulation and get the results, the temperature at each of these points is slightly off. IE, the profile might be 330.0 at one end to 335.0 K at the other and the results show the temperature as 229.1 to 333.9 K.
Has anyone run into this before? I need to improve the accuracy, but I don't know why the boundary conditions are off. I don't think it is due to interpolation, because the points are very precise and the mesh is fine at the boundaries. Thanks in advance for any help.
jcd84 is offline   Reply With Quote
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Fluent Ansys temperature coupling tensun FLUENT 0 November 14, 2010 06:31
Fluent Ansys temperature coupling tensun Fluent UDF and Scheme Programming 0 November 14, 2010 06:30
High temperature methane+air Peter FLUENT 5 January 26, 2009 19:04
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 21:48
