January 5, 2011, 03:39 |
parallel (cluster vs local) and UDFs
EH
Rep Power: 15 |
Is running parallel on a cluster of different machines the same as running parallel on a local machine? I am asking this based from the point of view of compiling UDFs. I have not been able to load my library after compilation; getting the following messages: Opening library "libudf"... Primitive Error at Node 0: open_udf_library: The operation completed successfully. Primitive Error at Node 1: open_udf_library: The system cannot find the file specified. Primitive Error at Node 2: open_udf_library: The system cannot find the file specified. Primitive Error at Node 3: open_udf_library: The system cannot find the file specified. Error: open_udf_library: The operation completed successfully. Error Object: #f All helps are deeply appreciated. Thank you. Sincerely, EH |
January 5, 2011, 13:28 |
Re:parallel (cluster vs local) and UDFs
Rajesh Gutti
You need to copy the compiled library folders to all the nodes on your cluster.
Rajesh Gutti Post Doc Fellow, Univ of Missouri-Columbia |
January 6, 2011, 03:24 |
EH
Rep Power: 15 |
Thank you for your reply. What do you mean by nodes on your cluster? Because at the moment, I only selected parallel in the FLUENT Launch window but did not do any partitioning to actually solve the problem in parallel.
January 6, 2011, 03:45 |
Bernhard
Rep Power: 22 |
In the start-up window, you have a Tab - Parallel Setting, the run type defaults to shared memory, but in your case this will not work of course, you have to work with the distributed memory. However, I do not have experience with it, so good luck
Compiling and Running UDFs on an IBM Power3 | S. Hollman | FLUENT | 0 | January 6, 2005 12:23 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 14, 2000 00:03 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
