How to get the pressure and pressure loss in fluent while using periodic
Old   January 4, 2011, 23:57
Default How to get the pressure and pressure loss in fluent while using periodic
wanchaoyi
winnawinna is on a distinguished road
boundary condition?
Streamwisely set the flow inlet and flow outlet as a pair of periodic boundary, and now I want to get the pressure loss between the flow inlet and the flow outlet. I tried two ways:
1. Cut surfaces in the position of inlet and outlet, and get the total pressure of both. (the value between the two surfaces are almost the same)
2. Find the pressure gradient in b.c.->periodic conditions, and multiply the length.
The results of the two ways are totally different. Which one is right?
winnawinna is offline   Reply With Quote
Old   May 6, 2011, 04:44
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
I've got the same problem. Does anybody can help us ?
Pressure field are very strange with periodic condition.
The second solution is described in fluent doc :
" 9.2.2 User Inputs for the Pressure-Based Solver ....
Note that the current value of [IMG]file:///C:/PROGRA%7E1/ANSYSI%7E1/v121/fluent/fluent12.1.4/help/html/ug/img2766.gif[/IMG] will be displayed in this field if you have performed any calculations. To update the Pressure Gradient field with the current value at any time, click on the Update button.
laurentb is offline   Reply With Quote
Calculation of Pressure Loss jason OpenFOAM Running, Solving & CFD 57 September 8, 2018 23:51
How to plot pressure drop with Periodic BC? bigfans FLUENT 7 November 8, 2016 12:28
Periodic pressure B.C. on collocated SMAC code waku2005 Main CFD Forum 0 August 19, 2010 00:03
Pressure loss in PEM cell with different profiles rodrigoscf FloEFD, FloWorks & FloTHERM 1 April 14, 2009 11:00
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 11:44
