setting different convergence criteria
Old   January 4, 2011, 03:26
Default setting different convergence criteria
osman
gubarrani is on a distinguished road
hi everybody!!!
Convergence in my simulation case is obtained when Cm (moment coefficient) is uniformed. I wanted to do somehow a program to check the difference of Cm value in the last X iterations and see if it changed a lot or not in order to see convergence...
Shall I do it via UDF or scheme programming or is there any other way?? Do you know of any place where to have a look to know it better??
thanks...
gubarrani is offline   Reply With Quote
Old   January 4, 2011, 06:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I have such a file (.scm), but very very few used
If you want it, give me your email via private message
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 13:44
Setting Convergence criteria for "rhopSonicFoam" instead of end time mecbe2002 OpenFOAM 2 March 7, 2010 05:24
Convergence Criteria edwin FLUENT 1 February 14, 2008 20:24
Warning 097- AB Siemens 6 November 15, 2004 05:41
