Non-nominal conditions in a radial turbine
Old   December 29, 2010, 09:04
Default Non-nominal conditions in a radial turbine
Pedro Nunes
Petro is on a distinguished road
Hello there!
I'm simulating a radial turbine.
For nominal conditions (no angle of incidence) the calculations perform well.
When i switch to non-nominal conditions (with a bit of incidence), the results are unrealistic (the efficiency is higher than for the ideal case). I also have to decrease the under-relaxation factors to obtain convergence.
Should I use a unsteady simulation to predict vortex shedding?
Petro is offline   Reply With Quote
Direction of Rotation of Radial Turbine ghoshi1983 CFX 8 June 19, 2012 11:16
Radial and Tangential Velocity boundary conditions N. A. OpenFOAM 4 September 2, 2011 08:21
Axial Thrust in a Radial Turbine Amit Roghs CFX 3 May 31, 2010 17:47
radial turbine flow analysis. ME Main CFD Forum 0 July 1, 2007 10:39
Simulation of Pelton Turbine: boundary conditions? massimo CFX 0 September 26, 2006 04:56
