ken
Rep Power: 15 ![]() |
Hi, I am still new to fluent and would like to seek advice on the simulation.
Currently, I would like to simulate 3D bubble column with VOF. My dimension of the column is height=60cm, diameter=20cm. My mesh size is around 60k cells, is that sufficient to capture the bubble formation? Can I actually get the 3D fluent tutorial from online? I know there is one for 2D bubble column, but for 3D, I am trying to get the animation for the bubble formation. Anyone can give me some advice? I know that I have to specify surface tension, and I search online the normal value would be 0.072N/m2, is that right? What velocity do I need to set? I think bubble column is not a hot topic and the simulation has been done for years. If you have one, do you mind to share your experience and result? |
Hossein
60k mesh is too fine, you have to set the mesh size according to the hole size of the sparger. but as a default, I usually set the mesh size to 1mm. 0.0735 for surface tension would be fine.
Hossein Amini PhD student in Biochemical Engineering; Computational Science and Engineering department; North Carolina Agricultural and Technical State University |
Bubble Column Modelling | dlaw | FLUENT | 24 | October 31, 2017 06:01 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
Help required for CFD simulation of Trayed Bubble Column using Fluent | art705 | Main CFD Forum | 0 | July 15, 2009 04:04 |
Bubble column | Sally | CFX | 2 | May 30, 2008 07:52 |
INLET BOUNDARY FOR BUBBLE COLUMN | Swarnendu | CFX | 1 | July 5, 2004 02:16 |
