intializing data in fluent from an available solution( from an opensource code)
Old   December 20, 2010, 08:11
Default intializing data in fluent from an available solution( from an opensource code)
Ayan
ayannath23 is on a distinguished road
Hi to everyone,
I have created and solved a case on a specific mesh in FASTEST3D (an open source code). Now I want to use the solutions to give as input to FLUENT12 for the same geometry but slightly different mesh.
Please give some idea about how to to initialize the data in Fluent?
Thanks,
Ayan
ayannath23 is offline   Reply With Quote
Old   December 21, 2010, 13:54
potrero is on a distinguished road
As I understand it, one way to do this in Fluent is through Profiles. You'll need to map the other solution's relevant data (velocity components, turbulence quantities, and matching locations) into a text file compatible with Fluent's Profile format (search the Help files for an example). Then, import the Profile, and you'll be able to select the relevant profile component (velocity, turbulence intensity, etc) when defining your Inlet Boundary Conditions.
potrero is offline   Reply With Quote
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
Fluent to Radtherm (export of data) akd FLUENT 0 December 3, 2010 02:07
Fluent Output Data Question fossu15a FLUENT 3 March 30, 2009 20:29
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
reading data into fluent co2 FLUENT 0 December 28, 2003 02:31
