Help with Meshing
Old   December 15, 2010, 23:47
Default Help with Meshing
Ankur Mour
Ankur is on a distinguished road
Hi all,
I am trying to model the air flow in a torrefaction chamber and I would be glad of any assistance.
This is the Geometry of the Chamber that I am trying to model. As you can see there are two rectangular boxes - one inside the other.
The external box has three circular pressure outlets for the air to be sucked out.
The inner box has a rectangular face at the front, as a velocity inlet for the air to come in.
The top of the inner box has plenty of holes for the air to enter the outer box from the inner box. (Like a zero thickness perforated sheet)
What i want to know is what boundary type do I denote the top of the inner box and the holes as?
Thanks a lot
Ankur is offline   Reply With Quote
Old   December 19, 2010, 16:47
Kevin Erhart
kerhart is on a distinguished road
Your question sounds like you meant to attach a sketch of your geometry, but nothing is there. From your basic description it sounds like you should be using a porous interface boundary condition though. If you provide a sketch or a little more detail you will likely receive more help.
Kevin
kerhart is offline   Reply With Quote
boundary type, chamber, meshing, perforate, torrefaction
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
