how can i give a boundary condition with pressure and velocity together |
December 9, 2010, 16:04 |
Rep Power: 16 |
hi everyone
inlet boundary condition= pressure 10Pa and velocity 10m/s outlet boundary condition= pressure 10Pa and velocity 10 m/s how we give a boundary pressure and velocity conditions together? thanks thanks thanks |
December 9, 2010, 21:02 |
Real Name :)
Rep Power: 16 |
akhenathon,
See my post to your same question in another thread. Regards, ComputerGuy |
April 24, 2012, 18:03 |
Rep Power: 17 |
ComputerGuy,
would you be able to post a link to the thread you are referring... Many thanks |
April 24, 2012, 18:52 |
Real Name :)
Rep Power: 16 |
http://www.cfd-online.com/Forums/flu...edge-face.html
I think this person was trying to over-prescribe the boundary conditions for the system. Regards, ComputerGuy |
April 24, 2012, 19:04 |
Rep Power: 17 |
I have seen people deal with a similar problem where one needs to set pressure and certain velocity vector at inlet while performing a compressible flow calculation...
In a vortex tube calculation, Skye et al (Int. J. Refrig.) made a small-area anular opening at one end of a pipe, then defined the vector direction in cyllindrical coordinates. A high enough inlet pressure on the small area inlet gave the nearly sonic inlet velocity they needed. They adjusted the area until the mass flux was also what was expected to be reasonable. If there are any other ideas how to achieve a similar scenario flux/pressure/velocity vector, I'd be very interested to read about it |
April 24, 2012, 19:23 |
#6 | |
Real Name :)
Rep Power: 16 |
Just to be clear, the original poster asked how to set BOTH the pressure and velocity (mass flow) at BOTH the inlet and outlet. Perhaps I'm missing something, but isn't that generally an overspecified problem?
If you're OK with performing an iterative calculation to solve for the pressure and mass flow, that's a whole other question. However, I see no way to prescribe them as boundary conditions. ComputerGuy Quote:
April 24, 2012, 19:32 |
Rep Power: 17 |
I agree with your reasoning...
My post was a bit of a diversion; I wanted to make the point that to define pressure + velocity vector on an inlet boundary takes planning of the area etc |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
How to give pressure boundary condition in SIMPLER algorithm | shyamprasad | Main CFD Forum | 0 | March 17, 2009 00:40 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
